HTC Desire Cell Phone Logo
Cris Posted on Oct 27, 2012
Htc volume control won't work
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Oct 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
Helped
7486
Points
80
You can always go into the settings and sound options to adjust it manually. The buttons may just not work. If you can be more descriptive I can provide a more in depth solution if necessary.
1 Related Answer
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Nov 03, 2011
SOURCE: All sounds on htc chacha seems gone, even when the
http://www.cellphonesguide.net/manual/8/
http://www.cellphonesguide.net/manual/9/
http://www.cellphonesguide.net/manual/84/
hope this helps
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
2helpful
Htc inspire 4g stuck on lock screen and won't unlock
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Screen goes blank and won't turn on
Well it seems like there is some internal hardware issue in your phone, or it's simply the battery of your phone is gone. If your phone is works on charging mode then it's the battery problem and you need to change the battery of your phone. else there is some internal hardware fault on your phone.
You may also try a hard reset method -
1. Turn the power off. If your HTC Wildfire S is frozen, pull the battery out and reinsert it
Many of the time hard resetting a phone will works.
Note. The hard reset method erase all the data from your phone.
Good Luck
Regards
4helpful
My phone won't send messages I got credit and still won't. also Mob internet don't work
You Can Unlock Your HTC Desire . Call Your Network Provider To Ask Your HTC Phone Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy HTC Imei Unlock Code From Third Party. Many Site Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
My phone won't start, when you press the power button it tries starting then when it gets to the windows phone screen it restarts. Please help.
PLease do a hard reset ... Here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Press Vol down for reset .
Thumps up if this works ..:-)
I am unable to logout my AIM account on my htc surround mobile phone. Explain to me in details to solve this problem.
Hope you have gone to settings > accounts & sync and press and hold on the AIM account to delete it . If that does not work , you will have to do the below .
Here is how you hard reset
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Dear expert, i have some problem with my tmobile htc hd2, i bought from ebay & it was unlocked until few weeks ago it worked normally. but one day the problem happened, i can't acces my...
First off please access your sd card via computer and make some space on the card . Its always ideal you keep 20 % space free on the card .
Now please do a hard reset of the phone ( considering that you are on default windows mobile 6.5 )
Go to
  1. Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
OR
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
NOTE : PLEASE TAKE A BACKUP OF YOUR DATA , USE PIM BACKUP,
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
