Any replacement parts for this 1968 4speed 6cyl sedan or Zenith 35/40 INAT Carb experts
SOURCE: need to know the flote height for a 1968 honda motorcycle 350
Hi! I presume you have a Kei Shein carburettor set up? if so there really isnt a float height as such, if you are experiencing flooding or fuel spewing out of the rear aperture it is more likely the float needle/valve is either worn or has foreign matter stopping it from shutting out the fuel supply.
When you take the float bowl off and look at the float you'll see at the end under a tang a tiny spring around the tang which is attached to the float needle careful removal will reveal all for servicing.
O.K. penny dropped? do you mean Needle Jet? if so try middle to start and check plug colour after good run, remember raising richens the mixture lowering weakens. Trial & error I'm afraid as mileage, wear and fuel quality all determine final result?
Paul 'W'
Onyer~EDson(:0)~[><
SOURCE: how do you adjust metring
GET A CARB KIT AND REBUILT ITONE BARRELS ARE EASY TO DO ALL INSTRUCTION ARE IN KIT AND IT WILL WORK LIKE ITS NEW ABOUT 30 BUCKS GET A CAN OF CARB CLEANER STICK THE RED TUBE IN THE LITTLE PASSAGES MAKE SURE THERE ALL CLEAN
SOURCE: Need radio code for 1995 Mercedes Benz E320 sedan
Its inside your car manual on the left side as you open it up, it'll be a lil grey card that will have the radio code written on it... read the manual and it'll tell you how to put the numbers in.
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems.
