Motorola Mobility H700 Wireless Headset Logo
Posted on Jan 03, 2009
Screeching i have the H700 paired with my playstation 3. when i go to turn iton all it does is screech in my ear ive tried uninstalling and re installing but the same thing happens can you help please
  • skywalker382 Jan 03, 2009
    my issue is similar, I am trying to get this headset paired with my PS3 but it won't accept a pass key of 4 zero's, I have no idea what to put in the pass key section.
Anonymous
Level 1:
Scholar:
  • Contributor 39 Answers
  • Posted on Jan 04, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
39
Questions
Helped
17217
Points
94
These trouble shooting suggestions where taken from here. There are more things they suggest trying but this cutout pertains to your problem more so than other suggestions. If these do not work I would recommend reading through that guide.
Noise or Feedback:
  • A screeching noise when you talk you are experiencing feedback. Turning your TV down should help.
  • Loweringthe headset volume can also help. Go to Accessory Settings/ AudioDevice Settings (where you test your headset) and you can set the micvolume there. Level 3 is a good start. If people have trouble hearingyou then you should raise to Level 4 or Level 5.
  • Ifyou hear an echo when you talk try turning the earpiece volume down onthe headset. Many BT headsets have their own volume control.
Also, while the PS3 is compatible with almost any Blue tooth 2.0 headset, I have heard of of problems like this occurring where the headset had to be replaced by a different model to solve the problem. As far as I know this is the only headset guaranteed to work by Sony.
Engine screeches when running. revving the motor makes it stop momentarily
Could be a belt screeching. Fan belt, A/C belt, Serpentine Belt, alternator belt, etc. Easiest way to isolate which belt is to open the hood and use your ears to see where the screeching is coming from. Left, right, front, behind the engine? Spray some WD-40 on the belt you think is making noise and if it quiets right away, then that is the belt making the noise. Either the tensioner needs adjusting or the belt needs replacing. The WD-40 does not hurt the car, it'll start screeching again in a few days when it wears off.
Screeching turntable
Try to pin-point where the sreech comes from. You can do this by keeping your ear close to the turntable. Or you can use one of those 'bent' drinking straws to narrow it down, put one end of the straw in your ear and listen. If you find it's metal rubbing together you can use silcone grease on it.
My ps3 makes a loud screeching noise when i turn it on
Its just dirty, clean it the best you can and make sure it has space to breathe
6helpful
Need generic pass key for H700
open boom on ear piece
turn on bluetooth on phone and go to paired devices
hold button on ear piece till lite turns purple
under paired devices click connect
0000 is the pass key
should work
1helpful
Motorola h700 ear piece
Try 1234....hope this helps...I believe someone else in here tried that code and it worked.
Good Luck
Loud screeching sound
GO INTO MENU UNDER NETWORK AND SELECT HOME(THIS KEEPS YOU PHONE FROM CHANGING NETWORKS AUTOMATICALLY
1helpful
The Dryer is not Squealing- It is SCREECHING FOR THE ENTIRE CYCLE...
could be rollor wheels that support rear of drum need grease or replaceing also have a slide bearing in frount may need lub or replaced
Pairing
i have a samsung r410 and have the same problem.... im thinkin its the phone....
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
