I've have the phone for just over a year and it wont charge when plugged in through the micro usb slot on the phone. I have previously been able to charge it by propping it up against a wall with the charger in place, however this doesn't work anymore. Thanks for your time.
Batteries are around $5.99-$8.99. By a new one. $5.99 for a battery for my Samsung Galaxy s5.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
SOURCE: LG shine wont charge
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
SOURCE: my enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
SOURCE: Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
SOURCE: My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
SOURCE: my new LG P970 won't
Go to settings, wireless networks, access points and then hit menu button then add access point and enter same address as the one that you are currently connected to then select the access point you just made and problem should be solved, reason why is there was a default proxy, this should fix your problem
