Husqvarna 22 Hp 46" Deck Yard Tractor Logo
Kate Posted on Oct 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have replaced the mower belt on my husqvarna lawn tractor but the belt is too tight and the blades are engaged all the time. I cannot find a tension adjustor, is there some way of adjusting as I suspect the old belt had stretched and the deck has been adjusted during services to take up slack. Now I have put on a new belt as per manufacturers recommendations it is too tight . Any ideas pls?
Anonymous
Level 2:
  • Expert 100 Answers
  • Posted on Oct 27, 2012
Anonymous
Expert
Level 2:
Answers
100
Questions
0
Helped
40066
Points
246
There should be a adjuster on the spring
5 Related Answers
Anonymous
  • 405 Answers
  • Posted on Dec 23, 2008
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Anonymous
  • 226 Answers
  • Posted on Jun 01, 2009
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Dwain Pippen
  • 377 Answers
  • Posted on Jun 15, 2009
SOURCE: knob on lawn tractor for blade engagement
Sounds like you need a new PTO switch.
Anonymous
  • 3911 Answers
  • Posted on Jun 01, 2010
SOURCE: i cant replace the deck belt on my husqvarna ct151 lawn mower
The manual shows how the belts are put on, if you do not have one they may be purchased through dealers or small engine repair shops or online. On mine there is also a little diagram on the top of the mower deck. Another way to check is find an identical one that is functional and look at its belt. There are only so many ways it could fit and these are all made by just one or two manufacturers so there is not much variance.
Anonymous
  • Posted on Sep 04, 2010
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
1helpful
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
BY pass red blade engage of quick check for a 2013
Are you sitting in the seat? Usually you can't engage blades if you're not in the seat.
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
The blades will no longer engage on my Husqvarna 1842 lawn tractor....all the belts seem to be in good condition. Any ideas on what the problem is?
Start by making sure the belts are actually on the pulleys and the tension pulley that engages when you go to engage the blades is functioning properly.
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
When engaging the blade for my Husqvarna riding mower, nothing happens. I recently had the mandrel assembly replaced for the left blade, and this is the first time I've tried to start it up.
It's possible the repair folks didn't properly reinstall the mower deck belt. Check that it's in place, and under good tension. If that's OK, look at the wires to the mower engagement switch (PTO switch) and make sure the connections are on tight. Then check the motor pulley where the PTO clutch is, making sure those wires still in place.
8helpful
2answers
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Husqvarna ride-on mower LT1536. We put a new
This seems to be the correct part no. for the 36" deck, is the belt definitley the correct one, it should have the no. 174978 marked on it.
2answers
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
