Panasonic VIERA TC-P50U50 50-Inch 1080p Full HD Plasma TV Logo
Ashley Garey Posted on Oct 25, 2012
Panasonic Viera not coming on and red light blinking 8 times.
I have a Panasonic Viera TC-P50U50. We have had it seven months and all of a sudden when you turn it on it immediately turns back off and the power light blinks 8 times. What does that mean and how can we fix it?
Remote code for my Panasonic TV Viera TC-P50U50 to program my universal remote
Pensonic TV 3 Digit Remote Control Codes:
095
863
261
Pensonic TV 4 Digit Remote Control Codes:
3778
3779
2186
To program most universal remotes to work with your Pensonic TV:
1 - Hold the setup button until the light stays red or green.
2 - Be sure the light stays illuminated.
3 - Enter one of the remote codes provided above.
4 - Remote blinks and code is saved.
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Tc-p50u50 cracked screen
It is not worth it to replace the screen. I found that everyone recommends scrapping tv or finding another broken tv and using that screen.
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
6helpful
Power button blinks red seven times on a 2007 Panasonic flatscreen VIERA.
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The "pop" is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Panasonic tc-p50u50 software update for media sd usb
It is a skilled work indeed. It will be best to contact any experienced service technician to do this. Check this link and see whether can you do it by yourself or not. It has details with illustration.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
