I have Samsung DVD-VR357 and Samsung TV. I have setup my equipment as directions in manuals using HDMI cables. I have great audio and video connection. The problem is I can not get the IR Blaster Cable to turn on the satellite receiver box to record. The setup is as follows: Satellite receiver, I've Red, White and Yellow cables connected to audio/video out, S-Video connected as well running to the Samsung DVD-VR357 AV/In and S-Video connected. The IR Blaster Cable is connect and placed within an inch of sensor on Satellite receiver box. The satellite box brand number for DirecTV I used code 1887 for direct TV listed in the manual. I am not sure if that is correct since I can not get the system to work. I can change the channel using the DVD-VR357 remote but nothing else. Please advise if anyone out have had this problem and what is the solution for this problem? Thanks
SOURCE: How to record ?
I don't know a whole lot about electronic equipment, but I've never seen anything connected in so many ways at the same time. Maybe the antenna and one other type of connection. The different signals from all the connections are probably confusing each other. I would try one connection at a time to see if the problem improves. Good Luck.
Dawn
