What is the Remote code for the Soyo TV Model # MT-SYTPT4218AB to operate on a ATT Uverse Remote
SOURCE: Programing Remote
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
SOURCE: need a remote code my new sanyo tv to go with
I went through all the Sanyo TV codes and then started entering in groups of 10. The U-verse offered 1103 i did 1100 to 1110 and it worked with 1107. Unfortunately at&T said you have to check the manufacturer which doesn't list universal codes. I was lucky on the Sanyo 18.5" LCD from Walmart using 1107!
SOURCE: Need remote control code for ATT U-verse
well i have a vizio 32' lcd hdtv and the code 1343 worked for me!! the 922 didnt.....1343
SOURCE: need remote code for emerson LC195emx LCD TV
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
