Dremel Variable - Speed Multipro Rotary Tool 395 Logo
Posted on Jan 02, 2009
Dremel Model 395 Rotator Stripped
Hi. I attached the Flex-Shaft to the 395 and started it up. I immediately heard the device straining to rotate but it wouldn't budge. I then switched it off as quick as I could but unfortunately it looks like the damage was done. The 1st like 4 threads on the rotator (the thing that actually spins, not sure if that is the correct term) are somewhat smooshed together. Because of this once a collet is inserted the collet nut cannot be tightened over it as it cannot grab the threads. This leads to 2 questions:
1. Before taking it apart any opinions on how hard it might be to replace this part? Like is it 1 simple piece or is this going to be major surgery?
2. Any suggestions on where to get parts? I am having all kinds of problems at Dremel's Web site and can only find a parts list for the 400 Series XPR.
Any suggestions would be most appreciated. Thanks, Charlie
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
682
Points
Http://www.ereplacementparts.com/dremel-395-f0130395ca-corded-multitool-parts-c-15440_15456_15474.html
Anonymous
Level 1:
  • Posted on Jan 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
682
Points
I would send it back to Dremel, they have been AWESOME to do business with, I have sent in 2 of my rotary tools, and because they couldn't be fixed, they sent me new ones at no charge, also, just bought one of their 4" table saws (off ebay) that didn't come w/an owners manula, I emailed Drwemel, and got one in today's mail, pretty kool for an item they quit making years and years ago. Hope this helps
Why does Flexshaft get hot after a couple seconds
Perhaps you are bending the shaft too much, or the original lube in the flex shaft has been compromised. Take it back to the dealer, for an exchange.
1helpful
Have Dremel MOD 395 motor runs and speed control works bot shaft won't turn--worth fixing ??? and how
Hi Larry, The tool that you require parts for was discontinued many years ago. Limited parts are available from Dremel. Inside the tool is a flex coupling and spline driver. The flex coupling is # 2615294309 and the price is about $ 1.25. This is the hollow plastic sleeve about 1" long with grooves on the inside, that goes between the motor shaft and the output shaft. The spline driver is # 2615294308 for about $ 1.00. Spline driver sits on the direct end of the motor shaft. The flex coupling sits over the spline driver. Spline driver is about 1/4", hard plastic with grooves on the outside. Total shipping for orders under $ 5.00 is $ 2.50. Orders over $5.00 is $ 4.00. There could be a tax charge depending on which state you live in. Here is how to order: Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa, MasterCard or Discover order. To order by mail: Dremel 4915 21st Street Racine, WI 53406 USA 1-800-437-3635 ext. 3636
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Where can I get a flex shaft attachment (Model 225 T2)?
Check w/ Home Depot and/or Lowes. If they don't stock they can get quickly
Need a Flex coupling. part #529430970 for model 395
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/Attachments.aspx
2helpful
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
32helpful
3answers
My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
The flex coupling is # 2615294309 and the price is $ 1.25.
The spline driver is # 2615294308 at $ 1.00.
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
3helpful
Broken flex shaft on Dremel model 232 broke
You can go to Dremel.com and find assistance or call their toll free number at 1-800-437-3635 and speak with their tech assistance. Let me know if you still need more help. Also I tried using the model number provided and it came up empty that is why I am directing you to this site yourself.
Dremel Flex shaft attachment model 225
Dremel has an exchange program for the 225 Flex Shaft. Send your flex shaft and 17.90 and they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264 Their phone number is 1-800-275-2052. Hope this helps. Dave
Using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
