SOURCE: I have a Scotts TurfMaster Gear Drive
Your worm shaft or tine shaft and gear assembly are probably shot. Welcome to the club. Long live American manufacturing.
SOURCE: MTD series 410 rear tine tiller drive wheels slip
I have the same issue with one I am working on. It appears the keys in the drive shaft are not rotating far enough out on the drive gear side to fully engage in the gear. I have studied and studied this and so far I have been unable to determine why. If I find out I will let you know. I am also trying to figure out what is supposed to pull these keys out of the till engagement gear.
SOURCE: mtd rear tine garden tiller . The wheeles will
Could be the shifter inside the gearbox or it could be a stripped gear or broken chain. The bad news is you will have to remove the gearbox from the engine and then open the gearbox to see what is going on. This is quite time consuming but taking to a shop for this is very expensive due to the labor involved. You can do it yourself if you pay attention to how you take it apart. I hope this helps you out.
SOURCE: I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
SOURCE: I am in need on line of the owners manual for
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
http://www.manualsonline.com/
http://dl.owneriq.net/7/7ba1d4f6-61b9-4c56-b878-fcfa51ddfeef.pdf
