Question about Samsung Televison & Video
No picture and no sound
Tv went off last night (no storm or power surge). the tv has 3 lights on the
front right hand side. i tried unplugging the tv for a while also. after i
plug back in the red standby/temp will light up. then i try and turn on
the tv. the red light will go out and the green lamp light will start
blinking a couple seconds later will here the chime that the tv makes
when you turn on or off. after about 15-20seconds the lamp light
will go off and the red standby/temp will light and go out and the
cycle stated above will repeat itself. will repeat itself for about
3 cycles then all 3 lights will blink together and that is where it will
stay until a try and power up again. the 3 lights are as listed.
first one (red standby/temp)
second one (green timer)
third one (green lamp)
any help would be appreciated.
thanks tim.
    Top Expert:
  • Samsung Master
  • 76,140 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Posted on Mar 11, 2017
SOURCE:
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 2337 Answers
SOURCE: Blinking red light
It appears in all cases that the power supply needs to be service. The blinking light might indicate that there are shorted parts or the voltage is low or a combination of both.
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
  • 106 Answers
SOURCE: My TV will not come on.
Have you checked the lamp? You can cosult your owners manual to find the lamp access panel. Once you determine that the lamp is bad, you can find one anywhere on the internet. Let me know if I can be of further assistance
Posted on Jan 18, 2009
SOURCE: Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Posted on Mar 21, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
Samsung LCD TV (Model UN65FH6001F) doesn't turn on? I have added more details in the below section.
There may have ben a power surge that caused an internal fuse to open. The power supply could have been affected as well.
May 15, 2018 | Samsung Televison & Video
We had a power outage due to a bad storm. The tv is on a surge protector. When I went to turn the tv on the power light will flash and there is a audible click that happens. The tv will not turn on. I...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Aug 11, 2010 | Sanyo DP42848 LCD TV
My tv won't turn on after it went out during a
Leave the TV off and unplugged for 24 hours then try it. If it still doesnt work you may need to consult an engineer. The TVs power supply board may have blown due to power surge/spike. I recommend getting a surge protector to avoid this happening in future.
Jul 10, 2009 | Panasonic Televison & Video
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Wii has no power after storm
There is a surge protection built in. Unplug it for 5 minutes then plug it back in, It should work.
Dec 10, 2008 | Nintendo Wii Console
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
Computer power won't turn on
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Jul 20, 2008 | Computers & Internet
Moxi DVR
You will probably want to get the audio module checked by a professional. It could be something as simply as a blown capacitor/resistor, but if you are not familiar with this, best get a professional to diagnose/repair the set.
Try this first:
Unplug the tv from the mains and remove all cables. Wait for about 10 mins. Now plug the TV back into the mains, while holding the power button ON. See if this resolves the issue.
I would also recommend investing in a surge protector/spike buster if have frequent storms in your area.
May 11, 2008 | Televison & Video
Green Light on the front flashing
Needs DM module repair = replace four 1000mf/25v 105 degree
caps..www.chrisandnat.com/projects/blinkingtv/blink.htm
.......................T.
Feb 07, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Televison & Video Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
