whenever i open the drive it is showing that "the nvtdm cpu has encountered an illegal instruction close to terminate the program" and drive will not opens. and a window showing the soundman.exe of "c" prompt(black screen) appears.whenever i open the drive it is showing that "the nvtdm cpu has encountered an illegal instruction close to terminate the program" and drive will not opens. and a window showing the soundman.exe of "c" prompt(black screen) appears.
AnonymousMar 30, 2014
when i install driver max exe an error comes cfgmgr32.dll was not foundwhen i install driver max exe an error comes cfgmgr32.dll was not found
You can't post conmments that contain an email address.
what PC (HP, model and number) what OS>? XP? we can never guess the OS you run.!
what version of loadrunner, there are so many (from v1 to V15 ??????)
and not all run on
windows 95 to W10.
sorry, impossible that.
the work around, is use the correct software.
for your unstated PC./OS
If XP and is infected, like all are,
then there is no work around, the fix there is to reinstall
the OS, clean. (AND LR and the APP under test)
or (long ago cured by OS upgrades) this...
Google DLL H3LL, that too is a big problem before VISTA.
this is a driver problem. there is an addition part to the error message. the last part tells you the DLL that needs to be reinstalled. take the name of that dll and do a search to find what item it drives and then reinstall that hardware
tvagente.exe
is used to use computer as a TV. If you do not use it, you may want
disable it. It uses excessive system and memory resources If you are
not using the TV application, you should remove it to improve your
overall system's performance. anyway try in run-msconfig-startup the entry for tvagent.exe and disable
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Hey, I have the same problem as you and im in the process of fixing it I researched it and found this... http://support.microsoft.com/kb/929135 (Note this is for Vista only) Use the instructions on how to clean boot your Windows and it should work...
did you update from sp2 to sp3 remove sp3 for one reason
fixed it by going to Windows Defender, Tools - Software Explorer and disabled AirGCFG.exe from automatically starting at boot.** Now I don't get the error message and the Dlink NIC card works just fine. AirGCFG is a NIC monitoring function and the NIC will work without it. Dlink was advised and reported back that SP3 was still Beta and they may work on the problem after MS releases the final SP3. I informed them that they did not know what was what and I would not hold my breath until they fix the problem. Found out the problem was due to a new version of the wlanapi.dll file introduced with SP3 that conflicts with the Dlink monitoring file.
** Note: AirGCFG did not show up in the "msconfig" startup listing. But does show in Windows Defender, with an explanation of what it does.
mimboot.exe is the startup application for Musicmatch Jukebox. It does not need to start with Windows. It looks like you may have deleted or unsuccessfully uninstalled Musicmatch Jukebox. Reinstalling the application should resolve the issue. If you don't want the program after the re-install simply uninstall it again in add/remove programs.
Please note: this can also be a trojan horse. If you haven't already I would suggest running a good anti-virus and anti-spyware program.
Im assuming you have BT Broadband? If you delete BT Helper or something along those lines from Start -> All Programs -> Startup that should fix your problem.
