LG 42LC2D 42 in. LCD HDTV Logo
Anonymous Posted on Oct 24, 2012
Powers on but no picture - LG 42LC2D 42 in. LCD HDTV
Steven Terry
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 16, 2015
Steven Terry
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
239
Points
Sonny Berry
Level 3:
  • LG Master 8,617 Answers
  • Posted on Oct 24, 2012
Sonny Berry
LG Master
Level 3:
Answers
8617
Questions
Helped
1723313
Points
23750
Does the audio stay working and just the picture goes out, or does everything drop out picture and audio?
  • Anonymous Oct 24, 2012
    the only thing that comes on is the power light turns from red to blue
1helpful
2answers
Hisense TV Red Flashing Power Light Has Sound But No Picture
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
Fix led to with dark picture?
problem in the picture power board
take it in and have it fixed
1helpful
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
2answers
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
Dodigital frames need batteries or electricity?
Some digital picture frames work with batteries, while some work with a power plug, and some have the option to use either method. Running off of battery power can be handy if a power source is not readily available. For a frame that is going to be used 24/7, a power plug is more convenient.
Read more: How Does a Digital Picture Frame Work? ' eHow.com http://www.ehow.com/how-does_4613713_digital-picture-frame-work.html#ixzz2IsRZGCgP
Jan 24, 2013 • Photography
1helpful
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Power but no picture
I doubt it is the picture tube...there are three of them.. a red. a green, and a blue. Would suspect something on the power/deflection board
Powers up no picture but shows picture on power down
Try unplugging the three convergence plug wire clips on the SSM board and then try to power up your set, let me know what happens.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
