After about 20 minutes it clears up and is fine for as long as I want to watch. I thought i would warm it up before watching one day. turned it on for an hour. then connected the pc via HDMI and the same sympton and it went away after 20 minutes of video input. so the symptom requires an active video input to occur and be resolved. Is this in the backlight inverter board?
SOURCE: Inverter opertion
Hello davidweldon,
If the inverter board is bad, I would suggest that you replace the whole board unless you have a SMD (Surface Mounted Device) rework station, and a background in electronics. I have worked on TVs where people have tried to remove SMDs and it never is an easy thing to do, so I would again suggest that you replace the whole board, because all of the components are SMDs.
Now as to your question, I have seen on these sets the majority of the time it is a driver transistor that goes bad.
I hope this helps,
Thank you,
Shuttle83
www.electron-age-technologies-llc.com
SOURCE: 42 inch DO42746 no picture or sound
It is still possible the z sustain board is bad. or an x driver board.
SOURCE: Sanyo DP46849 composite video input malfunction
Sounds like a damaged port or related circuitry. You could take it to a repair shop if you really want to use that port, wouldn't cost too much
SOURCE: I replaced the backlight inverter
Did you chaeck first to find out if the power supply is putting out 24vdc for the inverter board, and also if the inverter is getting the backlight_on signal from the main board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps
SOURCE: My Sanyo DP46848 has been having half of the screen
The left side of my tv is going black. Why is it doing this?
