I need to ask about a NFS-320/E/C (Fire Alarm Control Panel) and its compatibility with the sensor TC807A 1036 (Smoke detector). There are a new panel like this (replacement an older Honeywell panel burned) with 35 sensors TC807A 1036, and this don't works. Can you help me for this about?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
SOURCE: PIR Intruder alarm magnetic contact
Hi Bowdi,
Please find the below the information on the contacts.
You will fine two silver screws - This is your Alarm pair and this will go back to the alarm zone on the panel PCB.
The three other brass screws are just junction screws so you can join the cables to go to other doors.
You will need to join the black and blue together to make the tamper circuit.
Regards will
SOURCE: My Intellisense fg-730 glass break
http://www.cwasecurity.com.br/produtos/manuais/83_1237304479.pdf
Hi please find above your manual, in there is, should be all one needs to know...
And YES there is indeed a battery backup inside the unit, you need to get inside the unit to find and replace the battery, once inside it's all pretty obvious..
see below to for some info that may help?
http://www.diysecurityforum.com/index.php?action=printpage;topic=4195.0
