Can't build fuel pressure and fuel running out of carburator
SOURCE: My Homelite backpack leaf blower runs until tank is 1/2 full
I believe you to be correct in your diagnosis.
1) remove the fuel tank
*this will give you an idea of how lines are routed and fitted into tank
2) install a new hose through to tank fitting and make sure to retrieve the old hose & filter inside the tank, so that you can attach the filter to the new hose. The filter is weighted so that it falls to the lowest point to pick up fuel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: Homelite UT08550A leaf blower has only been used 3
Gummed up after 3 uses? Not hardly. Have u tried fresh fuel? A new engine can poss foul a plug untill it gets broken in. Id try a plug first. I wouldnt recomend going into the carb if your not familliar and comfortable with it. If it is the carb causing the trouble then the best bet would be to replace it
SOURCE: wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
