Componet located directly behind the tank ? evap canister ! Do you know how to test automotive electrical ? How to read an use a electrical wiring diagram ? Use a DVOM - digital volt ohm meter ? Do you know what a FPDM is fuel pump driver module (computer) Your best bet take it to a qualified repair shop or dealer ? Ford Electronic Returnless Fuel System Diagnosis Part 1 Ford
SOURCE: Ford F100 Fuel System
how hard was it to pump it by hand?Iwould be suprised if a mechanical fuel pump could be easily pumped by hand as the spring pressure required to hold the arm against the eccentric is considerable If its a cleveland or windsor you cannot pump by hand.I own a 1980 running a cleveland and found that if you put an electric pump as close to the fuel tank as possible and have a good original mechanical pump fuel delivery is no longer a problem.I had to do this as soon as i went to a 600 holley as the original pump was not able to supply sufficient flow.the electric pump doesnt have to be an expensive hi volume type,it only has to help to get fuel to the mechanicl pump
SOURCE: fuel pump location and replacement
You are looking for the constant control relay module- ( CCRM ) see below. The pump will be located inside the fuel tank.Most of the time , its the pump and not the relay but, it wouldn't hurt to check the relay out. Teh relay is housed in the CCRM. Its located behind the engine coolant reservoir.
SOURCE: 2001 ford focus fuel pump
Yes you do. Be careful of the plastic fuel supply line when you reinstall the assembly. The hose can kink, and you will not have fuel pressure.
SOURCE: wont start
Check your rotor, distributor cap, coil wire.did you change the module inside the distributor cap.
SOURCE: 2000 ford excursion wont start i sprayed carb
fuel pump relay is failing some times they get that way and also make you replace the pump and its the relay
