Every time i open my message. it says that my phone memory is full but infact there are no sms. Infact there is nothing other than some files that are protected by the phone. In my phone memory bar the highest that occupies is the bada application, when i tried to delete it. it says it is only available to be uninstalled from the main menu. But problem is that i have unistalled all the bada application that i have downloaded.
SOURCE: Message memory gets full though the capacity is 500.
yes... i am also getting same problem.
total SMS memory is 500 ie 200 for inbox , 200 for sentbox, 50 outbox and 50 for drafts. your my folder SMS's are still considering in inbox. that should not be more than 200.
thanks
kuldeep chanchal
SOURCE: message memory full
hi what the phone is saying is its capable of holding 500 message but in reality this means if you have enough free memory your phone can store 500 messages so what you need to do is delete all the sent/outbox/inbox/drafts message delete all the ones you dont need.
Also delete any pictures you dont need as these take up loads of mem also delete any ringtones that your never going to use as alot of the messages you got free with the phone you never use so make sure you delete any of these that your sure you dont want as these also take up loads of memory once you have done this you should find your phone will work just fine
SOURCE: sms memory full del some sms
Your Inbox Only support 200 sms... And when I say Inbox it includes your My folder as well... So you see 197+ 26 beyond your range... Delete Data from my Folder.... Problem solved.
SOURCE: Samsung sgh f480 If I try to move message to
Voicemail, e-mail, and other saved Memo's and such DO effect the SMS/MMS memory, sadly. So, start deleting what you REALLY do not need. Thats the best option.
