Question about KitchenAid KHHS179LSS Convection / Microwave Oven
How do i change a fuse in a kitchenaid overhead microwave
It seems to be stuck and I can't figure out how to un-mount it from between the cabinets. I un-did the bolts in the small cabinet above but it is still stuck there.
  • marielaura2 Jan 03, 2009
    Thank you for taking the time to respond. I had the panel removed but didn't realize there was a handle. Thank you for saving me from ripping the thing from the wall studs! See how simple it is when you know what you're doing?!
    Laura
    New Friend:
  • 3 Answers
The solution to get to the lock handle is correct when you need to unmount the microwave from under/between cabinets -- however to replace the internal fuse you simply need to remove the control panel in the front. To do this remove the louver (pulls off) and remove the one screw at the top of the control panel. Remove the control panel carefully as there are many wires and it won't pull that far out but far enough to get to the fuse which is located on the left about half way up. You can then replace the internal fuse and hopefully that solves your problem!
Posted on Jan 23, 2010
    New Friend:
My overhead samsung microwave oven working but I smell something like rubber, what can be wrong?
Jean
Posted on Nov 27, 2009
    Scholar:
  • 140 Answers
Hello,On the front of the microwave above the door is a louvered panel. You need to remove the panel ( usually it just pulls straight off ) and inside on the left you will see a metal rod that's bent 90 degrees. That is the lock handle. While lifting on the front of the microwave pull that handle out to release the lock. The front of the microwave will tilt down, you may have to help it start tipping. Once the microwave is tipped down you have to lift the back that is against the wall to unhook it from the wall mounting panel. Be careful to feed the power cord through the cabinet hole as your lowering it. Good luck and let me know how this works.
Posted on Jan 02, 2009
SOURCE:
How to remove overhead kenmore 1000 watt microwave
Unplug the power cord and make sure it will come out easily when you start to take out the mounting screws.There are 2 or more screws in the cabinet floor above the microwave. Be ready to catch the microwave once the last screw is removed because it will drop in the front. Then lift the back of the case off the tabs on the wall mount bracket and the whole thing is in your hands.
Sep 23, 2014 | Kenmore 63792 Microwave Oven
How to remove sharp 1480 microwave from the wall
If this is a built in mounted under an overhead cabinet, Just open the above cabinets and there will be 2 long screws facing downward that hold it in place, if it is a built in that is framed in then you will need to remove the frame and the brackets behind the frame that are holding it in place and then slide it out.
Aug 26, 2010 | Sharp R-1480 Microwave Oven
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
No power
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
At our Web site, we have a video available showing how to remove a typical over the range control
panel assembly in under 5 minutes.
Then you can get to the door switches to check them.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also see
http://www.microwavedisplay.com/doorsw.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 25, 2008 | KitchenAid KHMS155L Microwave Oven
Removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Aug 27, 2008 | Microwave Ovens
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
KitchenAid KHHS179LSS Convection / Microwave Oven Logo
830 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Craig Butler
Craig Butler
Mike
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
