I dont know , how to fix.
HTTP Error 408
Request timeout
Introduction
The Web server (running the Web site) thinks that there
has been too long an interval of time between 1) the
establishment of an IP connection (socket) between the
client (e.g. your Web browser or our CheckUpDown robot)
and the server and 2) the receipt of any data on that
socket, so the server has dropped the connection. The
socket connection has actually been lost - the Web
server has 'timed out' on that particular socket
connection. The request from the client must be repeated
- in a timely manner.
408 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown
robot) goes through the following cycle:
Fixing 408 errors - general
This error occurs in the final step above when the
client receives an HTTP status code that it recognises
as '408'. (Last updated: March 2012).
408 errors are often difficult to resolve. They
typically involve one-off variations in system workload
or operations.
Fixing 408 errors - CheckUpDown
If you see persistent 408 errors, the first thing to
consider is the workload on the Web server -
particularly around the time the 408 errors were
generated. If this is light, then you also need to
consider workload on the client system. If the computer
systems on both ends of the socket connection seem to be
running normally, then temporary Internet surges may be
to blame.
This error is highly unlikely to occur on your
CheckUpDown account, because there is usually only a
tiny interval of time (milliseconds) between our 1)
opening of the socket and 2) writing the HTTP data
stream through that socket. In exceptional
circumstances, this interval may increase because of
some operations on our computer systems e.g. we
temporarily suspend an executing process and this
happens immediately after the socket was created. Or the
two steps may follow quickly on our systems, but the
second step encounters an unreasonable delay on the
Internet. The acceptable interval between the two steps
could also be set very low on the Web server e.g. the
Web server is very busy, and has become a bit
'impatient' with attempted connections it views as a bit
slow.
Any of these conditions may generate an 408 error. But
they are all fairly unlikely to occur. In normal IP
communications, the time interval between the two steps
should be much less than 10 seconds, which should be
completely acceptable to the Web server.
I hope this helps.
