Please remove my name and address from your lists.
Thank you!Please remove my name and address from your lists.
Thank you!
AnonymousJan 18, 2009
I accidentely chose the french language on the OK button, and I would like the camera to display in english. Thanks.I accidentely chose the french language on the OK button, and I would like the camera to display in english. Thanks.
You can't post conmments that contain an email address.
Ok this may get alittle confusing but here goes. if you remember where the settings button is you can look for one of these words Sprache; Zunge they mean language in german or you can scroll down to Reset Alle Kamera Einstellungen which means Reset settings to default. this should do it
On the page that shows WHERE TO and VIEW MAP press TOOLS (the spanner symbol at the bottom right corner)
Press SETTINGS (The spanner symbol) or LOCALE (The blue symbol) on models that don't have a settings icon
Press LANGUAGE (the lips symbol)
There are 3 items on this screen; VOICE, TEXT LANGUAGE and KEYBOARD
To change the voice language to English press VOICE and select an English speaking voice
To change the text language press TEXT LANGUAGE and select English, or American English if you're in the USA
If the text language is already in German you probably won't know which is voice, text and keyboard. The German word for German is Deutch so when you see this beside one of the items you'll know this is the one to change the text language. This should solve your problem.
Press the HOME button to bring up the menu. Touch the pliers-and-screwdriver icon to bring up the Setup menu. Use up/down to select the eighth item on the menu.
Go under the menu and see if you can find something like "Sprache" (language) or "sprachen" (languages). Then find the one that says something like "Englisch" (English). Depending on your camera, the last part might even say "English".
I hope this helps!
Der Strom
Therecan be 2-3 choices under languages. One being the voice that speaks to you, and the other, the text on screen you read. Go back in and make sure that both are set to english.
You can go one of three ways. From the music/headphones icon, press down 3x (to get to settings);
right 1x (to enter settings); down to the fourth option/line (observe
the scroll bar to make sure you count from the very top) right 1x (to
enter the languages menu). You will find your own language in plain
text. It should work unless your setup is different or I miscounted somewhere. If that doesn't work, try updating the firmware. By doing that, it will ask you which language you would like to use on your Clip. If either of those do not work, plug your Clip into the computer. Then go to my computer under the start menu, find your mp3 player under the list (should be under 'devices with removable storage', or something to that effect). Right click on the mp3 player icon, and click "format". Go with the format it suggests, then reinstall the firmware from there. It will be like starting from square one.
I have Brother DCP-130C all in one Printer. When I installed the
software I chose English as the language, but when i am scanning &
when i go into printing preferences it seems to be in German. I
un-installed & re-installed but still not in English. Any ideas how I can change the language to english please?
Thank you!
