Every time i try to send or receive emails server error 3204 keeps coming up
SOURCE: can not send e-mail
If you have a spam blocker installed, like Spam Monitor etc you need to make sure it is running when you try to get your mail. If you don't have one installed then you need to check your settings in your email client and make sure you are pointing to the right email servers. From the looks for the Error Number this is indeed an email servers name problem. Just make sure you enter them correctly. They will look something like mail.something.com
SOURCE: Attachments to Outlook
Heyy... i must inform you that Yahoo do not support SMTP access. In other words i can say... it do no allow you to use n send emails from applications like OUTLOOK. If you wanna send such mails with attachment then please use GMAIL with outlook...it will work best...
SOURCE: I am getting this error when trying to send email
Microsoft Outlook 2002 (XP) and 2003
From the Tools menu, choose E-mail Accounts.
Click in the circle beside "View or change existing e-mail accounts." Click Next.
Click the email account you wish to modify and then click Change.
Click More Settings.
From the tabs along the top, click "Outgoing Server."
Check "My outgoing server requires authentication”.
Also, make sure to check "Use same settings as my incoming mail server."
Click OK.
Click Next.
Click Finish.
Microsoft Outlook Express
From the Tools menu, choose Accounts.
Select the "Mail" tab.
Click the email account you wish to modify and then click Properties
Select the "Servers" tab.
Check the box next to "My Server Requires Authentication."
Click the Settings button.
Ensure that Use same settings as my incoming mail server is selected and click OK.
Click Apply on the properties dialog box to confirm your changes and to close the window.
Click Close on the Internet Account dialog box to complete the settings change.
Click Close.
Testimonial: "Thanks for your help, but this did not correct the error."
SOURCE: yahoo.com blocks my emails
Tell your customer to look into his Spam Folder as well as add your Email Address to his Address Book and Safe Sender's List.
SOURCE: Email code error when sending messages: Error code 0X80040607 how do I fix this
Solution
Install the updated Windows Live Essentials 2011
For Win XP = Windows Live Essentials
System requirements for Win XP
For Win Vista, Seven, Server 2008 = Windows Live Essentials
System requirements for Win Vista, Seven, Server 2008
Update DirectX 9.0c (Juni 10)
Update NET Framework 4.0 (only for Win XP)
