Wtw6600sw2
Whirl Pool large capacity top load 2-years old if that, the controls -you have to push extremely hard and hold the start/on buttons in, sometimes it eventually starts. Otherwise you can leave it sit for hours come back and than it may start. The LCd dials do funny things and once it does start it periodically makes beeping noises while going thru the cycle. I am thinking that the control panel/brain may need to be replaced-? any help would be appreiated.
SOURCE: Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
SOURCE: whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
SOURCE: WHIRLPOOL FRONT LOADING WASHER MODEL #GHW9460PL0
I have a Sears front load made by Whirlpool. It had a problem locking door. I replaced latch/switch assembly and still would not work. Took top of washer off 3 or 4 screws on back of machine lift up lid and slide back. Make sure washer is unplugged. Presto you can see wiring and control. Unplugged connectors on control and plugged them back in then tried washer and it works.
SOURCE: the agitator does not spin. its a whirl pool
Broken coupling
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
