Just put in new ink cartridge, other one was empty, it keeps saying Toner Empty, when its not, it wont print recieved faxes, put prints from computer. Please help me, urgent, run a business
Searching on Google on how to access the fuse I found a page that
showed you how to reset the counter without replacing the fuse. It
was simple, access the TECH menu and select NEW CARTRIDGE. Here are
the instructions:
[menu] - [#] - 1934 - [menu]
Then select “NEW CARTRIDGE”
Restart Printer to get out of the TECH menu.
Try to search the menu of the printer for an option "Ignore Ink level" , it ignores the mesage "toner empty" and prints whatever you need to .
First remove the fuse from the toner (a small glass tube in the toner front side) then replace a 500ma fuse put into the printer then restart the printer will display CPU fuse error you remove the fuse from the toner, place the no fuse toner to the printer can be normal use.
Dear All
Please note the Practical Solution of this Problem, for that you have to follow this instructions and operate the Printer Menu As follows:
Press Menu
Press #
Tou seen the TECH Menu Option with Cartraige Instruction. Select Second Option i.e. "NEW CARTRIDGE"
Restart your Printer.
Caution:
Be Care full, Do not delete the Memory by Clicking on CLEAR MEMORY
Now your printer counter in Reset and You are eligible for Printing just like a new Toner
Enjoy..........
Sagarprateek
i samsung scx-4216f laser printer. But the the tonner indicator is on always and it cannot print or photocopy.
I have refiled the tonner but still showing the same thing.
Please tell me what may be the problem.
My e-mail address is [email protected]
Display says "Toner Empty" but I've replaced each colour and it still says the same thing. I can copy no problem, but can't print.
