I hooked up all the wiring, turned my car on and the screen came out and the cd started play. but for some reason the mute icon would show up on the screen and the sound would fade in and out of mute. and it wont stop. i didnt hook up the radio because it doesnt have the right plug for my car but when i put it on radio the mute still activated
Easy guys ill explain, if you pull the deck out and expose the wiring in the back you will see a small pink wire with a plastic and metal end, that wire is your parking break bypass wire,wut i did with my car was created a switch, its very easy, all you need to do is go to radio and purchase a ON/Off switch, it will have only two metal connector ends on that switch, basically all ya gotta do is find a suitable grounding spot for the negative or OFF side of the switch and then for the positive side...you guessed it attach the pink wire to the positive side. I had to make the pink wire longer for my switch location so if you know how to solder I wuld reccomend doing that than any other ghetto method, such as electric taping it and calling it a day, ding that may damage the system in the future
Do you have a switch so that you can watch videos while driving or did you put in a bypass code to over ride the system or can you only watch videos when you have the car on handbrake?
