SOURCE: gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
SOURCE: dryer is running but it's not hot
EVERYTHING IS WORKING FINE IT JUST WON'T HEAT. IT DOES NOT SOUND LIKE IT IS IGNITING
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
SOURCE: Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer for whirlpool and Kenmore styles or try this troubleshooting a ge style gas dryer
