Dishwasher I have a maytag jetstream dishwasher. The soap dispenser will not open during the washing cycle. What could be the cause of this and is it easily fixed?
I have the same problem, but it seems the upper dish tray is in the way, Why? I never noticed it before. Also the dishes aren't getting clean, even after several washes to rid of the soap still in the soap tray.
AnonymousMar 20, 2014
when I turn on the dishwasher, it does not start in wash, it goes directly to rinse and the soap dispenser does not openwhen I turn on the dishwasher, it does not start in wash, it goes directly to rinse and the soap dispenser does not open
AnonymousMar 24, 2014
soap dispenser does not open during wash cycle. Maytag model mdb8959awssoap dispenser does not open during wash cycle. Maytag model mdb8959aws
the soap container will not open during wash cycle. soap is still in dish after full cyclethe soap container will not open during wash cycle. soap is still in dish after full cycle
You can't post conmments that contain an email address.
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way.
A.
