1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1. blank
2. no image
3. only the satellite light is blue, the powercord is blue and the battery is blue
4. no noise
Please do the following carefully and let me know result : 1. Shutdown and Unplug your laptop. 2. Remove the battery from the laptop. 3. Wait 2-3 minutes 4. Now press ON (power button on laptop) for 1 minute 5. Then release the finger and wait one more minute. 6. Now plug in the power cable (dont insert battery yet) and press ON button. 7. Did your screen start working now ? (do you see windows loading)
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
It's possible that the LCD isn't working for whatever reason. If the computer is POSTing fine (Power-On-Self-Test it's what the two beeps symbolize generally) then it's likely that the LCD isn't functioning. My recommendation will be to hook an external monitor up to the laptop and see if you get video from there.
The Power Supply Might Have Gone Bad, or the motherboard could have loose connectors on it/be worn out. If It Is Still Under Warranty Have It Diagnosed. Does It Beep At All?
