sounds like you covered most all bases. without knowing pressures, I would look for a possible restriction. Since the TXV was replaced, are you sure you went back with OEM? If refrigerant was weighed in, was the drier an oversized one? It's rare but I have found some units that just don't cool right with the factory weigh in charge. You may want to try to charge by pressures. If it has a condensate pan with a hot gas line, be sure it is dry before trying as this effects the pressures. Good luck. Looking forward to hear about the fix.
I understand your Frigidaire freezer, model# LFFH21F7HWJ, is displaying -10 degrees and runs continuously. I also see that you were unable to set it to 0 degrees. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the temperature to 0 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
I would start there. If the thermostat has an off setting, turn it there and see if it goes off. If not, try turning it to it's warmest setting while the box is cold to see if it turns off. To test to see if the relay/ contactor is stuck/bad, kill power to the unit (Unplug or turn off breaker). Disconnect one wire to the thermostat. Restore power. If unit runs, bad relay/contactor. If unit does not run, I'd replace the thermostat. Make sure the sensing bulb of the thermostat is in the conditioned space of the box or in the return air (intake) side of the evap so it can sense the box temp.
Depends on the product you want to keep in the freezer. Usually you want to try and stay between 0 and +10 degrees for most items. Ice Cream must be -10 degrees minimum. Any warmer and it won't keep. Hope this helps.
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
The only thing I could suggest is looking at the evaporator (inside coil / cold bit) and making sure it is not frozen over reducing the airflow through the coil. If it is then put it onto a couple of defrost cycles to clear the ice build up. Not sure exactly of this type but would assume you also have a sight glass on the external unit, you can check this to see if when running the sight glass is clear (fully charged). Another check is looking at the compressor and the larger of the two lines (suction) should be cold back to the compressor (this line is normally insulated). However I would suggest your best course of action is a good refrig. techy. Hope this helps.
