SOURCE: want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
SOURCE: How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
