Power on, no picture? When it boots up the No Signal flashes but then no screen picture even though everything seems operationally sound. First thoughts is the video card / motherboard is shot - anyone else have any ideas? Going to connect to HDMI to TV to see if I get picture. Before this happened the computer base eas getting hot, so I'm thinking something melted etc.
If you have a Windows Installation DVD at hand, you can do as below:Step 1. Insert the DVD into your detective computer and reboot; Windows Error RecoveryStep 2. Set language, time and keyboard;Step 3. Click "Repair your computer";Step 4. If you have more than one systems on your computer, choose the one you want to repair;Step 5. Click "Startup Repair" to start restoring your Windows;Step 6. After startup repair is done, you need to take out the DVD and reboot the PC.
More info, visit:windows won't start
This could be a case of overheating.
First question, did the no signals sign appear out of the blue?
Check inside for melted components.
Clean your computer, remove all dust.
Check back with me.
SOURCE: video card upgrade
Can you try your old card? does your card have a 6 pin connector on it for power? Does your power supply have a 6 pin connector for video card power?
Lou
SOURCE: Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
SOURCE: Gateway GT5220 bios works no boot up
If the issue was the video card then there would be no display. If there was any display it would be discolored.
Try unplugging any removable media that's hooked up to the computer. After that try to boot it up.
If it still doesn't go anywhere then you most likely have a power supply issue on your hands. try unplugging an unnecessary components inside the computer such as any CD/DVD drives and removing any cards installed. Pretty much everything but the motherboard and the hard drive. If it still doesnt boot properly then you might either have to buy a new power supply or a new motherboard as long as you know your hard drive is good.
The thing si if it was an issue with the hard drive you would get an error message. If you seemed to have left out any error messages please post them.
SOURCE: My Acer ASpire M1641 desktop isn't booting, not
Even though the fan on the graphics card spins, it may still be the power supply. Try another power supply before anything else, its your cheapest option as well as a new motherboard will cost more
if this helped you please vote
Testimonial: "I kinda knew it was the MB, but it was good advice to try another PS and also to see if there were any beeps. "
SOURCE: My Dell XPS 730 needed
I believe you have used the wrong type of CMOS battery. Try putting the old one back in and see if it will boot. If not the CMOS NAND chip may be broken. If this is the case contact Dell and order a new one.
This is the all-in-one Lenovo A310 PC
When I hooked it up to the TV via HDMI I didn't get any picture. Called the local computer repair and they said they'd be able to fix for flat $250 - probably a chip on the mother board - they said?
