You can get Garmin Warranty support by following the steps below:
First: Contact Garmin Technical Support to receive an RMA number.
Call or e-mail a Garmin Technical Support Specialist to describe the problem and request a return material authorization (RMA) number. You will need to provide the unit's serial number (if applicable), your return shipping address and a daytime phone number.
Phone:1-800-800-1020 or 913-397-8200 Fax: 913-397-8282 E-mail: Tech Support
Second: Ship the unit, along with the RMA number, to Garmin.
Once you have received the RMA number, you also will be told what dock number to include in the shipping address. Ship the unit (insured) to the following address and include the assigned dock number:
Garmin International 1200 E. 151st Street RMA Number: (insert your RMA number here) Dock Door (insert the dock number here) Olathe, KS 66062 USA
I hope this helps & good luck! Please rate my reply. Thank you.
Hello thanks for using Fixya In HP Officejet J5780 All-In-One InkJet Printer cleaning the cartridge is not difficult, but it is
important to use the appropriate technique. The things you need is
"Cotton swabs" & "Distilled water" Now follow this procedure
Open the front door of the printer, located below the scanner
lid, by swinging it down. The print cartridges will move to a position
where they can be accessed
Unplug the printer to prevent the cartridge dock from moving away from the center of the printer.
Press an ink cartridge down until you feel a "click" then pull it out of the dock.
Dip a cotton swab in distilled water and use it to clean any
built-up ink from the metal contacts on the ink cartridge and from the
area around the ink nozzle. Avoid touching the nozzle itself, which is
located in the center of the bottom of the cartridge. Discard the cotton
swab if it becomes dirty, and use another to continue cleaning. Keep
cleaning until the ink cartridge is no longer dirty, then set the ink
cartridge aside.
Remove the second ink cartridge and repeat the cleaning process. Set both cartridges aside until they are completely dry
Replace an ink cartridge by holding it slightly below the
dock, then pushing it up and in until it snaps into place. Do the same
with the second cartridge. The black cartridge is inserted into the
right slot on the dock, while the color cartridge is inserted into the
left slot.
Close the front door of the printer, plug the printer back in, and turn it on.
I hope this solution will helpful 4 u Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful THANKS & Keep Using fixya
Hello thanks for using Fixya In HP PSC 1210 All-In-One InkJet Printer cleaning the cartridge is not difficult, but it is
cartridge aside.
left slot.
hope this helps please remember to take the time and give me a good rating if you appreciated my help.
Managing tracks in play view You can manage your tracks in many ways when playing them. You can, for example, delete a track, send a track, set a track as your ringtone or add a track to a playlist. The following icons may appear in the touchbar when a track is playing: Exit the play view and go back to the previous level Go to the music library Adjust the volume View more commands Delete the current track Send the current track Set the current track as your ringtone Add the current track to a playlist View track information Minimise the music player To delete a track 1 When the music player is open, tap > . 2 Select an option. To send a track 1 When the music player is open, tap > . 2 Select a sending method. To set
also can be done in personal settings:
Personal settings You can personalise your phone by changing the standby screen, profile or themes. Profiles You can change settings such as the ring volume and vibrating alert to suit different locations. You can create new profiles or change preset profiles. To change the profile 1 Select Menu > Settings > Personal > Profiles. 2 Tap a profile and select Activate. 3 Select Back. You can also press and then select a profile. To edit a profile 1 Select Menu > Settings > Personal > Profiles. 2 Tap a profile and select Personalise. 3 Change the settings and select Back. To create a new profile 1 Select Menu > Settings > Personal > Profiles. 2 Select Options > Create new. 3 Enter the settings and select Back.
I am assuming that it's disconnected when the Docked screen is showing.
There should be a small reset button on the bottom of the device. You'll need a paperclip or some other narrow object to push it. The player should turn off, and when you turn it back on, the player should rebuild. (Don't worry - you shouldn't have lost any data in the process.)
I think once it is set in the dock, it is a safety issue where it won't let you go through folders until the iPod is taken out of the dock. That is my experience.
if you have a PC, you're better of preparing a library for your
USB/IPOD devices with Librarian 1.50, but only if you are running
1.09(a) firmware on the IDJ2. This is the preferred and quicker way...
Do an upgrade if this is not done yet. Go to
http://www.numark.com/contentmgr/showdetails.php/id/1230/tt/5
for downloading the files.
When rerunning the librarian(for instance when adding tracks), choose
normal mode. It will add every playable track. (you could try this out
on an USB stick with some tracks on it for testing purposes).
If this doesn't work, you could have a corrupt library, and have to
rebuild(choose advanced in Librarian). Also, when you have created with
earlier versions of IDJ2 firmware, then you have to rebuild the whole
library.
Numark stated on their forums, when connecting a device, to never
choose update, but load instead. It can use mp3/wav/non secured aac
files, but not wma..
If there are any other questions, you can also send an e-mail to numark. They are reasonably quick with their responses.
while the docking station is in sleep mode or off not playing any music on the remote click the set button twice an alarm clock icon will appear and you use the volume buttons and the skip track buttons to set. To turn the alarm off hold the snooze button down until icons disappear. I lost the english version of my instructions but still have the spanish and can kind of figure out what it says still. Hope this helps
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
