Refrigerators Logo
Posted on Oct 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE refrigerator / Freezer - Erratic freezing
After replacing all known parts to cause erratic freezing (heater, defrost timer, cold control + ice rotator motor ) and another service call for additional adjustment. I still have erratic freezing cycles. Last night the freezer was sweating, ice cream soft, ice in box frozen over (had to hit w/ tack hammer to get loose enough to put ice in glasses. This morning freezer was cold again.
Richard Roth
Level 3:
Top Expert:
  • GE Master 9,472 Answers
  • Posted on Oct 23, 2012
Richard Roth
GE Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628560
Points
28464
Do you see any ice buildup on the back wall of the freezer or behind it?
3 Related Answers
Anonymous
  • 126 Answers
  • Posted on Dec 14, 2007
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Anonymous
  • Posted on Nov 17, 2008
SOURCE: Refrigerator and freezer not getting cold enough
I had this problem last year. I unplugged the the refrigerator and plugged it in an hour later it worked for a little while then quit over night. I finally called a sears repair they came 2 weeks later it was the motherboard, could have fixed it myself, what a hassle. Thankfully I have a fridge in the basement. Still this is a do it yourself.
Anonymous
  • 1489 Answers
  • Posted on May 05, 2009
SOURCE: FREEZER ICED OVER, LOWER COMPARTMENT NOT COOLING
Well, if the service person said the defroster is not the problem, there must be a good reason. But, I would go with a faulty defrosting system. Most likely suspects are the defrost timer and the defrost heating element.
2answers
Side by side refrigerator the refrigerator does not get cold but freeze works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
My GE fridge won't stay cold. The freezer up top seems to be cold.
How to check parts
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Kenmore Fridge, freezer compartment is cold according to thermometer, but ice wont freeze & frozen foods thawing out, weird. Fridge part is about 65 degrees. What could it be?
Should be around 10 degrees.
How to check everything
Ge frig does not freeze on freezer side
GE Model # DSS25PFMD WW, lights and fan are working not cooling
2answers
Ge side by side is freezing in the back of freezer, I have to defrost once a month. How do I check what parts I need and how to fix it
2helpful
Each side won't get cold. food starts to spoil
Freezer is partially freezing
2answers
Defrost not cycling
Hi. the Defrost timer assembly has failed. simply replacing this timer will fix the defrosting issue.
Concerning the refrigerators cold control. this is caused by a malfunctioning Temperature control assembly. simply replacing this device will fix the erratic cold control.
Now, i would inspect the compressor for its operational value before purchasing a temperature control assembly. If the compressor isn't cycling on and off and if it is making a very loud noise or pinging, this will confirm compressor failure. you will have to replace the compressor in this case.
If the compressor is coming on in a cycle and powering off without any abnormal noises, this will confirm temperature control failure. replace the temp control assembly in this case.
I will post the parts need below so that you may order the affected parts on line if you choose.
Defrost timer module.
Please rate and god bless:)
Freezing up
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Top Refrigerators Experts
vince
Johnny 1000
