My LG W1934S montior has worked fine for months (years?), but recently while using, it flashed and then stopped displaying in widescreen. Now there are black bars on the sides and it is compressed looking. Any ideas how to fix?
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
SOURCE: Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
SOURCE: When I start up, the monitor flashes on, and sometimes
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is usually caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
SOURCE: my lg monitor has turned green
This could be a sign that the monitor is failing, but it could also be a very simple solution as well. There should be two cables that come from the back of the monitor - one is the power cord and the other goes to the back of the computer. You will want to disconnect the cable from the back of the computer and then blow out the end with the pins in it (either with a deep breath or a can of compressed air. Now connect the cable back to the computer. You may need a screwdriver to remove the cable and you definitely want to make sure the cable is screwed in after you reinsert it even if it wasn't when you removed it.
If the display still shows a green tint, perform the same steps where the cable connects into the monitor. Some displays don't allow this part of the cable to be disconnected from the monitor, so you may be unable to perform this step.
Hope this helps,
Chris
SOURCE: my lg flatron model w1934s was working fine but
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
SOURCE: LG W1934S monitor. It displays an image for about
first you ensure that it is a problem with TFT or CPU. you can check it with another monitor. if it is working with another monitor then your TFT has been faulty.then you can repaired it from service center.
Testimonial: "Good direction for me to persue."
