Keeps stalling
SOURCE: I have a homelite model uto8550 26cc mighty
1. check fuel filter in gas tank (for clogged condition).
2. Check carb jet for dirt (squirt carb cleaner in jet and fuel inlet
Summary: your carb is not getting enough fuel to mix properly with constant air flow. Therefore, fuel supply needs to be cleaned... then you will run happy!!
-Jim
SOURCE: I have a Homelite Mighty Lite 26cs gas weed
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
SOURCE: i have the homelite mighty
you have a dirty or blocked carb jets strip down the carb and clean out the running jet
dont poke wire into any of the jets to clean them this will distroy them!!! use car cleaner and cmprest air if you can,,good luck mike
