When you turn the computer it comes up with a white screen with the finder logo going in and out with the screen flashing. I have read that it has something to do with the operating system but when i insert a cd with max osx leopard it just gos in and then comes out so I go not know how to fix it. Thanks
SOURCE: My iMac is not recognizing my CD/DVD-RW drive
Install your startup CD and restart the computer holding down the "C" if your computer starts off of it, the CD player is okay and you have a software problem, if does not start off the CD the CD/DVD needs to be replaced
SOURCE: white vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
SOURCE: emac model number A1002
It could be a hard drive problem or it could just be a software issue. Given the model, it could be running System 9 or X or both. If it is 9 it just may need to be blessed. The disc you are trying to load sounds model specific as opposed to Apple's retail discs which will load on any of their models capable of running that particular operating system. Whether it is worth fixing is really a judgement call, if you have use of a 2nd machine a hard drive / install disc can be had for cheap enough, as far as resell value, I would say no. Due to the limited information you have on the history of the machine I would suggest following these links to try and determine if it is indeed hardware or software:
Mac OS 7.x - 9.x: Troubleshooting Startup Issues
Your Mac won't start up in Mac OS X (Mac OS X 10.3.9 or earlier)
SOURCE: inch wide vertical white band on my Imac screen?
I have some good news and some bad news for you. First the bad news. the LCD panel in your unit is damaged beyond what 95% of people could fix at home. what has basically happened is the very very thin signalling cables that run around the edge of the screen is damaged. your only option is to replace the panel, which can be a major hassle unless you are very comfortable with a screwdriver and have at least disassembled laptops and know what the parts are.
Bad news as well, part is about $150.
good news. most shops can do this repair for you, esp. if they deal with laptops.
I can give you the replacement info if you wish to attempt it yourself, but as i said, it can be a hard repair to do.
Mark.
SOURCE: Computer freezes at grey screen
Important:
Do not click Continue in the first screen of the Installer. If you do,
you must restart from the disc again to access Disk Utility.
