NEED YOUR SERVICE TAG NUMBER
CHECK OUT THIS WEBSITE...
http://forum.gsmhosting.com/vbb/f88/bios-password-dell-latitude-e5500-1139381/
You need to remove the cmos battery .
Turn your laptop upside down .
Remove the main battery .
Open the 6 or 8 tiny screws and pluck open the back panel cover .
Remove the cmos small battery thas usuly under a tape like covering.
This will make ur laptop forget the bios password .
Turn the laptop on by attaching the main battery and just placing the back panel without tightning the screws but the cmos better still out . U should b able to login .
Then turn off and put in the cmos batter and tighten the back panel with the screws and done .
Below video should help ..
https://youtu.be/iHTMpGBO8X4
SOURCE: my Dell latitiude e5500 has problem with the keyboard
send it back if its new.. for a swap out under guarentee...
SOURCE: SD slot on my Dell Latitude E5500 won't read card
Check the Device Manager for any ! or ? (missing driver) and ensure the contacts of the adapter are clean.
Testimonial: "Thank so much. It's finally working for me. The driver was missing but it's taken care of now. Thanks for the tips!"
SOURCE: how do i enable presentation mode?
toggle between screen display modes by holding function and f8 together- there may be a few seconds delay between each settings so be patient
if that fails , then goto display settings and in advanced you should be able to select the displays you want.
service tag #7JWMDH1-2A7B
