The audio output section circuit has the fault. Check and replace audio output circuit board as card basis.
I have the back of the tv off where do i locate the audio output section circuit.
I found the circuit board and have the part ordered thanks for your help
Well I put in a new circuit board and the crackling noise is still there. Do you have any other suggestions.
SOURCE: power problem - Polaroid FLM 2601
i just repaired mine by replacing the 2 electrolitic caps that had a bulge on the top. they were 1000uf at 35 volts---works again!!!!
SOURCE: I have a Polariod FLM 3232 hdtv 32 inch tv The
Most universal remotes don't have the screen mode button. So, your better off with the orginal remote for the TV.
The cheapest place I can find one for you is NewRemoteControl.com
It's going for $49.95
It's a little pricey, but it will have all the option buttons for the TV.
I hope I answered your question. Please rate me. :)
SOURCE: how to access the inside of flm-2601
First- unplug it, Second- remove the back( can be tricky), Third- follow the AC cord to the power supply board and your there. Look for any Caps that may be bulged and replace them. Sometimes caps can be bad and look ok. Let ame know how you do>
SOURCE: Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
SOURCE: Polaroid FLM 2601 flat panel TV won't turn on
Power supply board is dead.Replaced the power supply board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Try Vance Baldwin a parts dist in florida
the handle Polaroid tv's
I replaced the audio circuit board and the crackling noise is still there.
