During the last spin cycle the unit stops with a sr code. about 5 min. later the door unlocks and you have to statt over
Machine control is attempting to drive the motor but is not seeing any tach response.
Visual check shows motor is not moving. (Locked, Hall Sensor fault).
Evaluate wire harness for loose or unhooked connections.
Testimonial: "Thanks, I tried to find loose connection. all seemed tight"
If all the connections are good, then you will need to replace the control board. Here is the part you need. http://click.linksynergy.com/fs-bin/clic...
SOURCE: maytag neptune MAH5500B spins 2 minutes and shuts
It's probably because you have a unbalanced load. I bet you are hearing the washer banging around. Take a few items out as the most common cause is you filled the washer with too much clothing.
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
SOURCE: maytag neptune washer stops after filling
Hello n8mtsn,
I would pull the 120VAC power cord to the washer for 10 seconds then power back up.
See if you can get into service mode. To enter Service Mode press and hold he Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”. If you can’t get into Service Mode I feel you have a Control Board issue/failure.
If you can get into Service Mode then go to page 15 of the SM and we want to try a Quick Service Cycle test. Follow the instructions to enter the Quick Service Cycle test and let us know the results. If the test will run it will take about 10 minutes.
Link to Service Manual for reference. Sears Parts Direct for reference.
Rich
SOURCE: Maytag Neptune MAH5500B stopped suddenly - no power or lights
Control Panel is bad, need to replace
SOURCE: Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge
and the front panel to the front shroud assembly. Do the same to the two
screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of
the cabinet by grasping the upper part of the front panel posts and
pressing in on the outer edges then twisting it inward. Once the front
panel posts are released from the cabinet, tilt the front panel away
from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
