Is there a limit to the number of files that you can put on a PNY 2 GB SD card? I tried to put photos on a couple that are 2 GB and once I got to about 350 .jpg files it wouldn't let me copy anymore onto the cards. I checked the free space available and still had 1GB + free space. I tried copying larger sized .jpg files and got the same error after around 350 files; this time there was less free space because of the larger files but I was still stuck around 350. Any suggestions???
SOURCE: Computer gives me an "error on card" message when it is put in the slot.
ik heb een micro sd 4gb in mijn gsm werk hij maar mijn bel toon werk niet steek ik hem in mijn fototoestel dan krijg ik die nie aan wat kan dat zijn kan iemand mij helpen
SOURCE: PNY 2GB MICRO SD MEMORY CARD NOT READING!!
In this case, it sounds like the card is bad. All you can do is try to clean the gold fingers with a soft cloth and alcohol, and hope that works. It may have corrupted data on it, and be unusable. The best way to know is to buy another one ($9 at Walmart), and then you will at least verify that your phone and computer are good, and the old card bad. Hope it's just dirty fingers, good luck.
SOURCE: I have a PNY optima sd 2gb memory card and it
hi my pny optima sd 2gb would recovry my picture i deleted how do i get the drive letter for my sanyo carmera and recovry my old picture
I bought two 2 PNY Gig micro SD cards for playing audio books on my new GPS. Neither card will hold more than 170 MP3 files (using less than 1 Gig). I tried formatting using NTDF vs FAT 32. In NTDF, it will accept all files in the book. But, alas, the GPS will only recognize FAT32. So, I bought a 4 Gig SANS card and it seems to hold as many files as I can shovel on it. Seriously doubt it's the extra 2 Gig that allows more files. Suspect PNY is the problem.
