Television keeps turning off
First check if you do not have the timer or sleep on the television turned on, if that has been checked, then the problem is related to the power source of the television.
This can be caused by heat, if there is so much heat inside the unit, then the leads on the panel could melt off causing a bridge on the panel thereby causing the television to go off on its own.
First assess the power panel for any burnt capacitor and bridged lead on the panel, then you check the control panel too for any melted lead.
Once the joint or bridged lead is found, correct by separating using a soldering iron to melt of the joining link.
Take care and good luck
