New LG top load washer (3 days old) error code E6?
SOURCE: LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
SOURCE: LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
SOURCE: LG Washer LE Error
Solved LE error for my WM1832CW by replacing Hall Sensor. Bought part 5016501KW2002A for $Cdn 26 at Sears parts store. Thanks to TC at http://www.howtomendit.com/answers.php?id=28214 for instructions:
1 Open rear panel. Take 17mm nut off (it's the only one)
2 Pull off what looks like a goofy hubcap (it's held by magnets)
3 Unscrew the six 10mm bolts and gently lower the coils
4 Remove and replace the Hall Sensor (plastic comb looking thing)5 Plug in the sensor and re-install the coils and cover.
30 minutes for me.
Test spin cycle if desired by following chart on page 19 of service manual at http://www.appliancefactoryparts.com/content/pdfs/125448.pdf
(note lower models skip step 10 (heater test).
Hall Sensor Part labelled as K351 in diagram on page 41 of service manual.
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
Try adjusting the load size, and make sure the unit is level.
