I have noticed that my rear door speakers are not working, i've checked the fade control and the front speakers are ok but no sound is coming out when you put the audio on the rear speakers. I was wondering if a fuse may have blown, does anyone know which rate of fuse covers the rear speakers as it's not clear in my manual. thanks Ian
SOURCE: 2000 Ford Focus electric locks/acuator failure recurring problem
I would follow their recommendation as I had the same problem with my car. They unhooked the power to that door and it was fine. The problem was a short in the wiring in the door that was causing the problem. So maybe get them to check the wiring in the door as well.
SOURCE: Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
take the bulb back out have someone sit in car apply brake get your self a circuit tester and check to see if this circuit is carrying efficient 12 volt current! some times in cold weather these bulbs get hot with long period of breaking and when released condensate and rust begins and you get what you have perhaps bad socket! this would be a ideal location to begin and probably end,
SOURCE: 2005 GMC Yukon Denali XL - Climate Control issue-
Are you aware of any codes that may stored in the body control module and do you hear a clicking or ticking noise in the rear?
SOURCE: 1997 Dodge Ram 2500 Cummins Turbo Diesel
The cruise control on y 1997 dodge cummins diesel 4x4 suddenly stopped working.I checked the fuses but they are ok.any solutions?
