HP Officejet 6310 screen is blank, the camera icon at the memory card port is blinking, although no cards have been inserted. The computer recognizes the printer, and informs me that two docs are in queue but printer is offline. Printer seems to be frozen, any help is greatly appreciated.
SOURCE: Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
SOURCE: HP 6310: memory card light flashing, printer will not turn on.
Sounds like a good fix, how does one go about reseting the firmware?
SOURCE: Snow Leopard 10.6.0 does not recgnize hp officejet 6310 printer
Your printer is supported in Snow Leopard. However if it does not work go to the following link and follow the instructions. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01846935&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Testimonial: "Thank you very much Clay, at last I could put my printer back to work. "
SOURCE: i have a hp psc 2355 printer everytime i insert
I had the same problem with my HP L7590 All In One. After trying a number of
things to reset nothing worked. Then I tried this just as a last resort and it
worked.
Insert the/a memory card( it will tell you that you can only use one card at
a time).
With the card still in turn off the printer using the power button.
Wait for 30 seconds then turn power on again.
The screen should say reading card. So wait for it to finish reading and all
should be fixed.
If this does not work, try again using a different card.
good luck
Send me Kudos if it works.
