SOURCE: Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
SOURCE: CAN'T IDENTIFY THE MODEL OF MY TOILET AND SEAT
Look inside of the tank the number will be stampes into the porcelin of the inside of the tank...
heatman101
Testimonial: "thank you great help Ira Beu"
SOURCE: I have a new Kohler
is there a chance you have an air pocket in the flapper itself... try replacing flapper with a solid black rubber one.... they have more weight to them maybe the lever on the out side of the tank is getting caught up on the bottom of the lid
SOURCE: There is a slow seep of water into the toilet
It's definitely coming through the flapper valve. Look for some interference or crud that prevents the flapper from sealing well. Does it happen intermittently, or constantly? If you can't find the interference try a different style of flapper valve. good luck. Al K
