Trying to connect Sony VAIO VGN-NS230E to Sanyo tv with VGA cord but won't pick up connection.
Look and see if it appears as a monitor in your display settings, if it doesn't, then another good first step would be to update your video card drivers (go to this page and select "Video" then download " Intel Graphics Driver"). If none of this fixes it try the VGA cable with a different PC and see if it works.
SOURCE: Need VGA drivers for Sony Vaio VGN-FS840/W
Here's the link
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFS840W
dont forget to rate
SOURCE: Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
SOURCE: i want to set up my sony vaio (vgn-bx567b) vga external display port to my sansui dft275 27" tv
if the tv has the correct input just plug it in and switch the tv input. if thers no input its kinda tricky,youll get horrible resolution
SOURCE: how do I connect my sony vaio vgn-fs920 to a tv?
I found this web site with step by step instructions on connecting to a TV. I haven't tried it yet but it may be helpful to you. http://www.labnol.org/software/tutorials/how-to-connect-laptop-computer-tv-screen-lcd-hdtv/2331/
SOURCE: sony vaio VGN-SZ430N/B
I'd suggest ring back Sony support and tell them that your OS is Windows 7 - not Vista. Therefore, you need the upgraded VGA driver because the Vista driver is incompatible with Windows 7. Hope it all goes well. If my suggestion works for you, please do rate me. Thanks
