Sharp VL-Z500H Mini DV Digital Camcorder Logo
Amrik Posted on Oct 20, 2012
Addapter connected but not charging for sharp VL-Z500
Addapter connected to handicam but not charging the battery the red light comes up on initial plug in but after some hours of charging start flasing
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Nov 03, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
4845
Points
25
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on May 22, 2007
SOURCE: Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
Anonymous
  • 148 Answers
  • Posted on Mar 09, 2008
SOURCE: how to get video onto a pc
use your cd to install the drivers onto your computer. Connect camera via usb and use the pixel software that came with your camera or you can use Windows Movie Maker to download your recordings.
Anonymous
  • Posted on Aug 11, 2008
SOURCE: Sharp view cam vl a10
my view cam is blury when you try to play any movies on it.
A
Anonymous
  • Posted on Oct 06, 2008
SOURCE: sharp vl-nz50
i need the software and the driver for my video camera
Anonymous
  • Posted on Oct 16, 2008
SOURCE: Drivers for Sharp Viewcam VL-Z3E
please send to me driver for Mini dv sharp viewcam VL-Z1
Will not turn on or charge
Try to use other Power addapter with same voltage and connector.
I need to buy a ac addapter for my portable speakers
Go to RadioShack with your adapter and get the exact replacemtn.
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Battry not charging,lap top works ok through mains addapter presario c700
There's a chance that the battery could be bad. Take the battery out, and see if you're getting power to the battery contacts inside the computer. If you are, the battery is definately bad. If you aren't getting power, you're going to have to take it apart to find the faulty wiring or connection in the power circuit.
Sometimes if you google your computer, you will run across tips and blogs (with photos) of people who have taken them apart.
Good luck, and hope this helps.
2answers
Laptop computer won't turn on...
this is ur battery problem so just get ur baterry cheked
Ac addapter not working
I had the same issue when I first got my scanner. There is a switch in the battery compartment that you need to set so it will charge the batteries. It is there so if you're using non rechargeable batteries you wont charge them in ruin your scanner when they leak/explode. Hope this works for you.
How to get video onto a pc
Top Sharp Video Cameras Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
