There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
Enter here to find assembly diagrams and parts for your model.
Contact the seller by phone if part is not listed on the website.
It is easy to replace. Turn power off to the oven. Remove the screws holding the element to the inside of the oven, Carefully pull the element out of the oven liner until you can unplug the wires from the element. Hook up your new element and ease it into place and re-install screws.
You can get the part from any whirpool servicer or you can order it from Sears.
