Acer AL2671W 26 in. LCD Television Logo
Anonymous Posted on Oct 20, 2012
Acer AL2671W wont turn on
Hi My Acer AL2671W's power button light wont turn blue(it stays as orange when i turn on my computer(it usually does) and the buttons on the front doesn't work. I have to keep turning it off by pressing the button on the back and pulling the power cord for like 20 mins to turn it on. Any solutions? Thanks
  • Anonymous Oct 22, 2012
    i mean when i press the buttons on the front, nothing happens
Anonymous
Level 1:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Contributor 41 Answers
  • Posted on Oct 22, 2012
Anonymous
Contributor
Level 1:
Filmmaker:
New Friend:
Answers
41
Questions
0
Helped
50019
Points
52
Sounds like a problem with the power supply board, typically power surges will cause fuses and capacitors to blow. If you go to tvrepairkits .com you can find a power supply kit with instructions that will allow you to repair this problem yourself. They also have coiled solder which works really well...hope this helps.
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 04, 2009
SOURCE: acer al2671w wont turn on on button turns from green to blue
Replace all caps on main board and preferably the others too and you'll have a nice set again. The set is an excellent design just the capacitors used are not of the highest quality.
Anonymous
  • Posted on Nov 26, 2010
SOURCE: My Tv wont turn on, the standby light stay orange,
Hi, l had the same problem. HAD !!
l bought a universal remote control (5 euro), but unfortunetly no codes for Acer in it.
Then l did the setting up by auto search and YES : there was a code. But, wheeehh, it did not work.
A little bit sad l took the Acer control and guess what: it worked again!!!!! l guess the TV had a total reset, and l use only the Acer remote control now.....
Female and blond!
Anonymous
  • Posted on May 22, 2012
SOURCE: I have a AL2671w LCD Acer TV ON OFF switching
Replace C380 and C348 - Done
What is touch pad onmy acer aspire 5532, and how can I turn it on/ use it?
I just so happen to have the same computer, look at the top where the on and off switch is at, on the left side is the on and off button for the touch pad. You should see a orange light on when the touch pad is disabled. It's the button with a drawing of a hand on a square. If the orange light is off then the touch pad is enabled, now you have a different problem.
Now go to Device Manger (via start,control panel, Systems & Security -- should see Device Manager in blue), go to Mice & other pointing device, right click on the Alps info, then click on update device driver. If Windows doesn't automatically update, then you have to go to Acer's webpage, then support, then drivers and downloads, fill in the info on your computer to be directed to the proper driver, then download the driver file for Alps mouse/touchpad. This should help (I hope), good luck.
W Thought it was the computer - so I chont power on. Would, for a while come up with no signal message, but now blue light barely flickers. Thought it was the computer so I changed computers, worked for...
A good rule of thumb to follow is: if the power button turns orange/red when it goes out, it's usually a problem with the monitor. If it stays blue or goes off, it's a problem with a driver or cable connection. Good luck!
The unit will not switch on from the remote or the button which only glows orange and will not turn blue. What can be done?
Take it to a repair shop, the orange glow signals a fault in the power source of the tv and it must be fixed by a pro.
3answers
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
1helpful
My Tv wont turn on, the standby light stay orange, When i press the button it should go blue and switch on but it wont.
Female and blond!
3helpful
Acer al2671w wont turn on on button turns from green to blue are these tvs junk or what
Top Acer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
