ZEEPAD Brand 7inch 4gb Android 2.3 Tablet Pc, Inbuilt Wifi, Camera, Logo
Posted on Mar 01, 2018
My zeepad 7.0 worked, then the screen went weird by fading out now I have nothing??, now it will not turn on. Its
My zeepad worked then the screen started fading I then could no longer she a picture at all. Last it will not turn on. It was full chared then all this happened . I have it charging now it see it it will turn on. What would make the screen fade out and then no longer be? thanks Tammie
1 Related Answer
Anonymous
  • Posted on Feb 22, 2013
SOURCE: my zeepad 7.o android will not pass the first screen showing zeepad alone.
Am having problem to open up my tablet, when i powered it the icons don't show up for me to unlock it.but it shows the wifi signal and the screen picture i put on.
Why did wifi stopped working on zeepad?
Go to the parameters and check the wifi section,
make sure it is on
if it is , turn it off and on again
Rate ma answer Thank you
My son's Zeepad 7.0 won't turn on.. tried charging it. Unfortunately, still nothing. He has had it almost a year.
Most probably there's a break in the charging circuit. Is the charger in working order? CHECK THE OUTPUT VOLTAGE OF THE CHARGER. Try booting with the power connected. If it starts, then the battery is dead. If still doesn't work, then need to check internal circuit.
1helpful
Why when i turn on tablet android picture appears then black screen
When you turn it on, what should appear is a little lock that you slide down to unlock the screen. If you are getting a blank screen there is probably something technical wrong with your zeepad. I would contact the company,particularly if you are still under warranty. I have had mine almost a year and have had no problems with it. When not in use, I keep it plugged in to keep it charged up. Have you charged it the full 8 hours before using?: Other than that, I am at a loss as to your problem. Wish I could be more help.
1helpful
My zeepad wont do video
There is an option in Skype settings to turn on video. Check that it is on. IS the camera in your tablet working?
7" Zeepad 7.0 Allwinnwer is fully charged but wont work
I am problem with my tablet.. it wont go on home screen at all,, stay on andriod blue guy.. can i replace new one or something to make it work
Zeepad 7.0 not connecting to wifi
the turn on wifi button when I turn it on it turns back off
Top ZEEPAD Tablets & eReaders Experts
nexrad_chris
Ngoro
 Mikey
Mikey
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
